Podcast No. 8 – Interview with Arthur Schiwon about Nextcloud Flow
Nextcloud - Nextcloud Hub 26 Spring: Built together, designed for the future
Nextcloud Hub 26 Spring is here. Check the release blog post and explore all new features!
Read more
In this eight-episode, our host Ingo talked with Arthur, Senior Software Engineer at Nextcloud, about Nextcloud Flow.
Nextcloud Flow is the workflow engine of Nextcloud. It offers flexible, user-defined event-based task automation. Apps can register events or triggers which can start a flow, as well as actions that get executed once a trigger is hit and the constraints are satisfied.
Find the feed on our podcast page! If you have not heard the previous episodes, check them there as well.
So tune in!
