The problems with Big Tech AI data collection: privacy concerns and how to protect your data
AI privacy concerns are growing as Big Tech keeps collecting data. Learn the risks and how privacy-first AI solutions help protect your data.
Read MorePlease update to a new version to keep your data safe!
If you are using Nextcloud Hub 8, 9 or 10, we strongly recommend you to update to version 29.0.16, 30.0.10 or 31.0.4 respectively. Maintenance updates include important bug fixes, stability and security upgrades. It is a quick and safe process, as always!
On 17th April 2025, following 10th April updates, we released out-of-band hotfixes for Nextcloud Hub 8, 9 and 10 to address the issue with installation of the new instances. While you could upgrade an existing Nextcloud instance to versions 29.0.15, 30.0.9 or 31.0.3, you could experience issues with installing them anew.
For your information, the enterprise releases for Nextcloud Hub 8, 9 and 10 will be published on Tuesday, 22nd April 2025. This is due to these versions shipping a fix for the installer.
Please note that the current version of Nextcloud Hub 8 (29x) marks its End-of-Life.
Found an issue? Please report any issues you find in our GitHub repositories.
Updates are available for:
Major versions that have reached their End of Life no longer receive further bug fixes or security updates. Support for major releases may be extended through Nextcloud Enterprise offered by Nextcloud developers via Nextcloud GmbH. For more details to help with planning your updates, check the documentation page.
Welcome Nextcloud Hub 10 – our most integrated, modular platform for secure collaboration. Our latest release comes with reinforced performance in every app, deeper integration across the platform, and dozens of new features that will make your day easier:
Nextcloud’s minor releases primarily focus on addressing security vulnerabilities and functionality bugs, avoiding major system overhauls that could jeopardize user data. Keeping your server up to date is vital, and our approach to testing and validation ensures that upgrading to minor releases is generally smooth and reliable.
For mission-critical Nextcloud systems in enterprise settings, consider switching to Nextcloud Enterprise. The tier provides you with ultimate deployment confidence: direct access to the Nextcloud engineering team, full assistance throughout deployment and integration, and peace of mind for system administrators. If you’re responsible for maintaining Nextcloud in your setting, this option may be the ideal solution for you.
