Note: There will be no more releases of Nextcloud Hub 1 (22.0.x). Upgrade to Nextcloud Enterprise to continue to get security and stability updates or move to Nextcloud Hub 2 (23.0.x or 24.0.x) or Nextcloud Hub 3 (25). Don’t forget that running web-facing software without regular updates is risky. Please stay up to date with Nextcloud releases of both the server and its apps, for the safety of your data! Customers can always count on our upgrade support if needed.
Nextcloud Hub 3 was released last month and we highly recommend that you upgrade to benefit from the latest features. Check out the release announcement here.
End of public support for Nextcloud Hub 1 (22 series)
Nextcloud Hub 1 (22.0.x) is no longer maintained. We will continue to release security and bug fix updates only for Nextcloud Enterprise 22. If you are a home user, move to Hub 2 (23.0.x or 24.0.x) or Hub 3 (25.0.x) as soon as possible. If you use Nextcloud in a commercial setting, check out our Nextcloud Enterprise as that is likely more suited for you. As always we strongly recommend you update to ensure you have a secure and reliable content collaboration platform that respects your digital sovereignty!
This is, of course, also true for apps: Keeping them updated has security benefits, besides the new features and other bug fixes.
Stay safe: keep your server up-to-date!
Minor Nextcloud releases are security and functionality bug fixes, not rewrites of major systems that risk user data! We also do extensive testing, both in our code base and by upgrading a series of real-world systems to the test versions. This ensures that upgrades to minor releases are generally painless and reliable. As the updates not only fix feature issues but also security problems, it is a bad idea to not upgrade!
If you are maintaining a mission-critical Nextcloud system for your enterprise, it is highly recommended that you get yourself some insurance (and job security… who gets blamed if the file handling system isn’t working as expected?). A hotline to the core Nextcloud developers is the best guarantee for reliable service for your users, and the job safety of you as a system administrator.
Time to own your data is now. Introducing the new Nextcloud Hub, a powerful open source collaboration platform that puts you in control. Discover improvements in performance, design, and security, and lots of new and improved tools for your daily work and life.
Following the overwhelming success of last year’s Nextcloud Summit, Nextcloud is proud to launch its second edition of the Nextcloud Summit, taking place on 9 June in Munich, Germany. During this unique event, we want to address the wider market around digitally sovereign collaboration technology, providing a space for organizations, governments, and experts to connect, […]
Over the last year, AI has become a popular topic. Some is hype, some is substance. Some is good, some is bad. We want to give you the good, not the bad, and ignore the hype! AI has a ton of opportunity – but also risk. So we put you in control – off by […]
Service:Matomo
Cookies description:
_pk_id*: 13 months
mtm_cookie_consent: 30 days
