The problems with Big Tech AI data collection: privacy concerns and how to protect your data
AI privacy concerns are growing as Big Tech keeps collecting data. Learn the risks and how privacy-first AI solutions help protect your data.
Read MoreUpdate:
Due to a regression in creating multiple share links we had to pull NC 28.0.13 and 30.0.3. We will follow up with a hot fix release asap.
Please update to a new version to keep your data safe!
If you are using Nextcloud Hub 7, 8 or 9, we strongly recommend you to update to version 28.0.13, 29.0.10 or 30.0.3 respectively. Maintenance updates include important bug fixes, stability and security upgrades. It is a quick and safe process, as always!
The updates include a number of important bug fixes and performance optimization, as well as other improvements in all supported Nextcloud Hub versions. You can find the full changelog on our website.
Updates are available for:
Nextcloud Hub 9 lets you stay connected like never before: federated calls, auto-magic with Nextcloud Flow, collaboration through a new medium with Nextloud Whiteboard, a big design redo and much more!
What’s new in Nextcloud Hub 9:
Nextcloud’s minor releases primarily focus on addressing security vulnerabilities and functionality bugs, avoiding major system overhauls that could jeopardize user data. Keeping your server up to date is vital, and our approach to testing and validation ensures that upgrading to minor releases is generally smooth and reliable.
For mission-critical Nextcloud systems in enterprise settings, consider switching to Nextcloud Enterprise. The tier provides you with ultimate deployment confidence: direct access to the Nextcloud engineering team, full assistance throughout deployment and integration, and peace of mind for system administrators. If you’re responsible for maintaining Nextcloud in your setting, this option may be the ideal solution for you.
